603,929 active members*
2,809 visitors online*
    Nov 2006
    104
    Gantry Vs XY table
    What are the pros and cons of a gantry vs a xy table with a ridgid Z axis?
    This would be for a small setup ~15 inch table
    Dec 2003
    24260
    It all depends on what the intended purpose is or used for, if only 15" table, the rigid set up might give you a wider usage, the gantry method generally does not have the rigidity for decent milling.
    Al.
    Albert E.
  1. open table vs closed-table gantry setups
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2008, 06:35 PM
  2. Moving gantry or table?
    By igolfat8 in forum Commercial CNC Wood Routers
    Last Post: 03-10-2008, 03:24 PM
  3. Movable table vs gantry
    By aggie_67 in forum DIY CNC Router Table Machines
    Last Post: 12-20-2006, 01:11 PM
  4. Gantry or table?
    By skaha in forum DIY CNC Router Table Machines
    Last Post: 10-12-2006, 05:06 AM
  5. Gantry or Table??
    By jetstuff in forum DIY CNC Router Table Machines
    Last Post: 02-16-2006, 03:39 PM
