603,366 active members*
3,177 visitors online*
    Jan 2004
    668
    Gas Shock Question
    The last post was very confusing to me and not so conclusive an answer. So here's my question. I want to put two 30 lb.shocks, one on each side of my square column. Do I get 60 lbs of lift out of this or just 30 lbs.? This is for a manual machine. Just need some resistance so I can use the head without it falling to the table.
    Jul 2005
    12177
    Two side by side give you 60, the two shocks add together.
    Think about it this way; You can lift 100 lbs, it would need two of you side by side to lift 200.
    Get a few bungee cords and experiment; they extend not compress but the priciple is the same.
  1. Gas shock for Z- axis
    By maxboostbusa in forum Benchtop Machines
    Last Post: 01-31-2008, 01:22 AM
  2. Power Supply / Shock Hazard...?
    By whidbey88 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-13-2007, 05:39 PM
  3. Gas shock on knee - how?
    By txcowdog in forum Bridgeport / Hardinge Mills
    Last Post: 03-29-2006, 04:44 AM
