603,800 active members*
3,983 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Gathering for new build, looking for info.
Results 1 to 5 of 5
    Sep 2012
    16
    I’m starting the adventure of self-learning a bit of CNC and starting by building my own.
    Ultimately I would like to be able to cut aluminum and I’m thinking no larger than a 25” x 25” platform.
    My son is currently in a machining class in high school, so I thought this would be cool to work on together.
    So far I’ve purchased.
    4ea, G213V
    G213V Selectable Resolution Digital Stepper Drive
    4ea, G723-400-4
    G723-400-4 NEMA 23 Step Motor
    I’m not sure about the breakout board.
    How is the PMDX-126 or PMDX-122 specifically with the PMDX-134 motherboard?
    PMDX.COM - Products for CNC and motion control applications
    Or
    The C35 from cnc4pc.com specifically with the RJ45 breakouts ( not sure if compatible with G213V)
    Thanks!
    Mar 2003
    35494
    The PMDX-126 is at the top of the list of breakout boards. It would be my choice.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2012
    16
    From what I'm reading that does seem to be the best for what im willing to pay.
    Ordered
    Multi-Mode Breakout Board
    Item # PMDX-126
    Simple Motherboard for Geckodrive Stepper Motor Drivers
    Item # PMDX-134
    26-pin Female to Female Ribbon Header Cable, 18 inch
    Item # PMDX-HDR26Ribbon-18
    Any suggestions on a power supply?
    Sep 2012
    16
    Time to hit the manuals and figure out how to wire this contraption... :drowning:
    Mar 2011
    584
    Nice choice. I've been helping a friend that has a PDMX-125 & PDMX-134 and if I ever build another machine I'd most likely build one with their stuff.
  1. Gathering parts. Some advice on rails.
    By In2deep in forum DIY CNC Router Table Machines
    Last Post: 04-10-2012, 11:04 PM
  2. Gathering inspiration and sharing information.
    By cncadmin in forum EnRoute
    Last Post: 12-03-2011, 03:20 PM
  3. Gathering inspiration
    Last Post: 11-10-2011, 06:50 AM
  4. aspire and cnc gathering
    By cabnet636 in forum Camaster
    Last Post: 10-09-2009, 09:19 PM
  5. CNC Mill conversion gathering information..
    By rsrunreal in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2008, 08:46 PM
