603,940 active members*
2,004 visitors online*
Thread: GCode
    Jan 2005
    4
    Smile GCode
    :banana:
    I use Deskcnc controller/driver and software.
    In my NC files when I run the machine the G00 (rapid move) codes do not work. I have to change them to a G01 codes with a fast feedrate.
    What is my problem?
    Thank you
    Nov 2004
    260
    Well lets see, hum your rapid moves are not working?
    Do you know why they not work?
    G00 = a G with two zeros
    Are you typing it correct or are you using Letter O's.
    Maybe you should get them to work.
  1. Autocad to gcode
    By JamesMI in forum Autodesk
    Last Post: 12-02-2011, 09:54 AM
  2. Is it possible to get a gcode into Rhino
    By MrBean in forum Rhino 3D
    Last Post: 04-03-2005, 01:41 PM
  3. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  4. dxf to gcode problem...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-19-2004, 07:02 AM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
