Please,
Does someone help to find information about gearboxes ?
Alex S.A
Please,
Alex S.A
What kind of inforatmation are you looking for????
Try Boston Gear.
Albert E.
I am looking for tech information to know it better.
Are you looking for construction design or usage design?
If designing for gear reduction, two of the principle requirements are the required final torque and the motor to load inertia.
The input torque to output torque is a direct ratio of the reduction and the inertia ratio will be reduced by the square of the reduction.
e.g. if a 10:1 ratio is used, the motor or input torque will be increased by 10
and the inertia of the input(motor) to load ratio will be decreased by 100.
Al.
Albert E.
