Originally Posted by
Mariss Freimanis
WON'T EXIT FAULT troubleshooting.
A lit red LED means the G540 will not run. You must get a lit green LED to use the G540.
Four conditions will place or keep the G540 into FAULT (red LED):
1) Incorrect parallel port configuration in BIOS.
2) Miswired and/or shorted motors.
3) No charge pump signal.
4) E-STOP input not grounded.
1) Boot your PC, go into BIOS, set the parallel port to 'EPP'. 'STANDARD' will not work. Do this first.
2) Unplug all motor DB9 connectors during setup. This eliminates motor wiring issues. The G540 has short-circuit protection circuitry that will place the G540 into FAULT (red LED) instantly no matter what else is going on. This is a latched condition that is designed to be non self-clearing. The only way to reset it is to recycle the power supply or cycle the E-STOP input.
3) Earlier G540 REV3s require a 5kHz or more Mach3 compatible square-wave watchdog timer (charge pump) signal to be present to enable. It is designed to be . Other CNC programs may not generate this signal at all or it may not meet the Mach3 standard.
Recognizing this, as of Friday last week (Sept 19), we have been shipping G540s with an internal slide switch that removes the charge pump as a requirement for enabling the G540. The switch presently accessible only when the cover is removed. The next revision (REV4) will have the switch accessible externally.
Until then, if you are not using Mach3, remove the G540 cover and slide the switch in the direction away from the DB25 connector to disable the charge pump input. The default position is for Mach3 enabled.
4) During setup (no motor connectors attached), jumper E-STOP to POWER GND with a short wire loop. Connect your E-STOP switch afterward once you get the G540 to enable.
Following the steps listed above, the G540 will enable (show a green LED). Connect your axis motor connectors one at a time. Recycle the supply after each new motor connect. This will help identify a miswired axis motor; should the dreaded red LED come on then the last motor connected has problems. Otherwise it's all Hades to figure out which axis motor of the 4 has problems.
Once all used axis motors get a green LED, wire-in the E-STOP switch. A red LED again will indicate a wiring problem there.
Hope that helps, it's kind of easy. We have been doing this about 80 times a day here during final G540 test. That's how many are going out the door every day.:-)
Mariss
