Originally Posted by
Deb.bosch
Hello
My question is for all the Gecko users. I want to use the G540 stepper drive and the source of step and direction is a ControlLogix PLC.
1.Would a 48V, 10A power supply be good enough for the G540.
2.I am not using a Mach3, so can I can give the step and direction signals directly to the terminals 2 to 9 at the DB25 parallel port at G540.
3.What exactly is fault mode that is mentioned in the setup guide.
4.What are the maximum no. of connections that can be made at a particular terminal
