Will this work with any motor, or is this lmited to one particular model?
Does it require a modification to a/the motor?
If this driver is designed for one specific motor, what is the resulting continuous torque of that specific motor, and what are the applications it is designed for?
So it sounds like someone can now use a lower torque stepper to achieve more power at higher speeds?
Unless I'm completely lost, it sounds like a higher torque rated motor is less necessary since now a motor will be able to maintain keep the torque from dropping off at higher RPM's.
Because Power is T*RPM's, since a stepper's torque drops off at higher speeds, power is lost. So having found a way to stabilze torque at higher speeds would be the key so that power is not lost. Correct?
Therefore power at higher speeds would be possible due to a modified torque curve.
I've been hearing a lot lately about mid-band resonance with steppers. What are the concerns with this now? If I recall, the 203V's are supposed to be able to dampen or eliminate MBR. Can I assume the new drive will do this also?
Sorry to be so lengthy... I find it pretty interesting.
Thanks.
