588,604 active members*
9,214 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Geckodrive = great customer support!
Results 1 to 20 of 20
Hybrid View
    Dec 2004
    25
    I recently purchased 3 G210 drives from Gecko.
    and I smoked one of them(the other 2 work great by the way).
    I sent it back in hopes of having it repaired but it was not repairable.
    They are sending me a new drive at no cost(even shipping) anyway!
    they are also sending an opto-isolator to turn it into a 201 for me to try
    free!
    Also very helpful with suggestions, etc. during a phone call to them.
    Best support I have seen on electronics!(or anything else)
    Randy
    Oct 2004
    173
    That's awsome!! Mariss has also been very helpful with me before and after purchasing my tropical creatures. The old saying stands true, even today... You get what you pay for!
    Allen
    Mar 2003
    294
    I second that.
    I had a long wonderful conversation with Mariss today about getting my 201s working (mostly about finding the common). Most of what he said was over my head but man, that guy knows his stuff! Thanks again! Can't wait to try them out.
    Oh yeah, if your trying to find the common use a Mouse port or game port (pin 1 has +5).
    taus
    www.cuttingedgecnc.com
    Thanks,
    tauseef
    Mar 2003
    6855
    Yeah common is NOT common but +5 volts. I had to use a external 5 volt power source to get it to work with the +5 from the computer the voltage was not a full 5 volts it was like 4.44 and the gecko drive did'nt like that.
    Mar 2003
    294
    Yeah,
    I tried and tried most of the night but could not get them to work. I think I did try an external power supply too but no go. I am going to try pin 1 on the game port for the +5 as suggested by Mariss.
    I did ask if they get many calls about this problem and he said that about 10% of the people that buy the geckos use them as hobby and they (hopefully) will up date the instructions or website for us little guys.
    I can't wait to them out and get my K2 cnc!
    taus
    Thanks,
    tauseef
    Mar 2003
    6855
    Power supply should have worked it's needs a full +5 volts, that's all it took to get mine working.
    Mar 2003
    294
    Where do you put the negative wire of the power supply or do you just stick the + wire into the common of the gecko and plug the supply into the wall. Doesn't it need a completed circuit?
    taus
    Thanks,
    tauseef
    Mar 2003
    6855
    You attach the +5 to the "common" and the ground to the power ground on the Gecko drive.
    Mar 2003
    294
    So the power ground is getting the (around) 36 volts from the main power supply and the negative wire of the 5 volts too?
    thanks
    taus
    Thanks,
    tauseef
    Mar 2003
    6855
    Ground is ground, what is important is that the +5 is going to the "common" and they will all share the same ground.
    Mar 2003
    294
    Ok, I am really trying to understand this and as you can tell paul doing a poor job at it Not the wiring anymore but the how and why.
    So the negative terminal on the gecko is going to get the negative wire from the 36V power supply and also the -5 volts too. (total 41V) or is this not the right way of looking at it.
    The positive terminal on the gecko is going to get the positive from the 36V power supply and the +5 is going to go to the common.
    Right.
    Isn't the power distribution unequal...am I making this harder then it really is
    thanks again
    taus
    Thanks,
    tauseef
    Mar 2003
    6855
    Ground is ground, you're not adding to any voltage. To complete the circuit you must ground the power supply. The 5 volt power supply needs a ground that can come from you're main power OR you can just connect it to the same terminal on the geckos ground and that +5 volt (red wire) can be connected to the Geckos "common" terminal. Geckos common needs to see +5 volts.
    Mar 2003
    6855
    The reason (correct me if I'm wrong) the +5 volts from the computer does not work is because their is no ground back to the geckos, you using the computer ground which I believe is floating?
    Mar 2003
    294
    Sounds good to me! Thanks Paul. I will try it out when I get home tonight.
    taus
    Thanks,
    tauseef
    Oct 2004
    173
    I got a small power supply from cnc4pc.com for my 12v (cooling fan) and 5v needs. It was very reasonably priced....here is a link. I was going to use the game controller plug (DB17 I think) but decided not to....more crap to wire to the PC.
    Link
    http://cnc4pc.com/Mini_Power_Supply.htm
    mine works perfectly. Just got my motors running...woooohooooo. My first CNC and I was nervous about waisting all my money by burning it all up (flame2) . Anyhow, it all worked great and Mariss was a big help. So was jfettig (his user name here), good guy who knows his stuff!!
    A.James
    Mar 2003
    294
    Hey guys,
    I got the geckos to work using pin 1 on the game port. Also works using some pin on the mouse ports (just check the 4 wires as 2 of them on mine were 5 volts.) I am FLOORED at how much slower they move compared to my half step board. I know, I know, microstepping-more steps-faster computer-larger power supply
    They do sound VERY smooth and are a lot quiter! Hey James, if you like you can also build a 12v and 5v power supply very easily using 7812 and 7805 power transistors from your local radio shack (or such). Probably cost you around $7 bucks total. The link you sent however looks very professional!
    Nice stuff
    can't wait to get my K2
    taus
    Thanks,
    tauseef
  17. #17
    Mar 2003
    6855
    How many volts is you power supply? I'm running 80 volts and it's very fast. That's cool you got it to work, I prefer a external power supply that using the computers myself, but hey what ever works.
  18. #18
    Oct 2004
    173
    Great, Thanks for the advice!!
    A.James
  19. #19
    Mar 2003
    294
    Hey Paul,
    I am using a 36V (24v transformer setup) and I would say it is about 1/4th as fast as before. Well it seems that way but looking below it is about 2.5 times slower.
    Before I was getting 10 mm/sec with 400 steps per mm (around 23 in/min) now I am getting 4.5 mm/sec with 2000 steps per mm (9.5 in/min). I used my Pentium III 850 mhz computer and it was as quick as before. HOWEVER, this computer is windows 2000 and does not have DOS...so I made a dos disc and it works but keeps running off of the a: drive.
    I plan to get 2 24 volt transformers and if all is well I should have about 67.2 volts. What transformer setup are you using to get the 80 volts?
    I wish windows 2000 just had DOS so I could use my CNCPro easily.
    tauscnc
    Thanks,
    tauseef
  20. #20
    Mar 2003
    35538
    Is it slower because your step rate isn't fast enough?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. WOW! This is great! I'm not the only one!
    By eford8 in forum DIY CNC Router Table Machines
    Last Post: 07-01-2005, 10:20 PM
  2. BobCAD?
    By BPT in forum BobCad-Cam
    Last Post: 06-21-2005, 06:39 AM
  3. Please Help with geckodrive
    By Biggermens in forum Gecko Drives
    Last Post: 01-03-2005, 06:29 PM
  4. The AMSOIL Preferred Customer Program
    By WallCrawler in forum News Announcements
    Last Post: 07-20-2004, 03:45 PM
