603,988 active members*
3,161 visitors online*
IndustryArena Forum > CAM Software > Esprit > Geometry from 3D surface
    Hello,
    I need to get the geometry from a 3D surface to make a chain, so I can use that chain to add a milling operation with Conical mill.
    I have done it before but cant find it anymore.
    See the picture as an example. The black (geometry) in the back is from the grey part in the front, now i need to find out what steps i need to do to reproduce this.
    Apr 2017
    10
    Re: Geometry from 3D surface
    I'm pretty sure you need to create a FreeForm, not a chain, to machine that feature. You'll probably need a knitted surface, too.
    Apr 2017
    10
    Highlight and select solid model -> Right click -> Copy... -> Smash -> Click to have checkmark in "Wireframe" -> Select tolerance -> OK
  1. Replies: 0
    Last Post: 04-20-2015, 10:09 PM
  2. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  3. Replies: 3
    Last Post: 03-07-2014, 06:26 PM
  4. Replies: 8
    Last Post: 05-13-2009, 01:16 PM
  5. Replies: 0
    Last Post: 02-11-2009, 03:53 AM
