Bought an old Gerber 404 that was in service up to the time of the sale. Perske spindle.
Plan- shorter term is to rewire to closed loop steppers and UCCNC controller (I was planning acorn but I had UCCNC hardware around). I will reuse the OEM limits and Spindle wiring.
Using 3NM Nema 23 motors with 8mm shafts. I am hoping to then use a rigid coupler, machined to 11mm OD, to mate up with the OEM pulleys.
The slightly longer term plan is to change out the lead screws with 20mm10 Pitch ball screws/nuts. I was told that you can't buy the 404 Y screws and they are 2KUSD each regardless, which is insane. From looking around, I don't see anyone that has made that switch before, which is strange to me as it seems relatively simple.
I am pulling off the OEM servos, related wiring, and will not use the main controller box at all. I'll probably keep the VFD box. If anyone is interested in those bits, let me know.
I have previously had an even older Techno Isle machine that had similar mechanics (with ball screws) and that was a great machine. My main machine has moved on to a 5x10 Chinese ATC, this is just a secondary unit.
Another question.....those 20mm linear bearings must have a non-Gerber version somewhere, I would love to know that information!
