587,193 active members*
2,590 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Gerber RS724X to Gcode Converter???
Results 1 to 4 of 4
    Apr 2003
    99
    I am looking for a software that can convert Gerber RS247X circuit board photo plotting format to CNC Gcode.
    I have tried the internet and I found some suggestions, but the process is a pain. I would like to run one program to do just the conversion.
    Anybody?
    Aug 2003
    31
    There are a couple of commercial products that do just that for you. You can try the limited version for free. Kellycam and deskcnc are capable of doing the conversion to create g code for pcb fabrication.
    Give a try. JOe.
    SuperDAD
    Apr 2003
    99
    Thanks for the info. on the DeskCNC. I've tried it and it worked.
    I am designing my boards in Protel and created the Gerber files. In DeskCNC demo, I am able to import the Gerber files and have DeskCNC isolate the circuit traces, then generate the G-code.
    Finally in Mach1, load the G-code file and mill the copper clad board which I will do next after I finish building my router.
    Oct 2009
    Hi all!
    Is there any program open source that can do that (gerber to gcode)?
    I mean, something written i C++ that i can read and compile by myself.
    Thank you very much
    Edoardo
  1. Gerber RS724X to Gcode Converter???
    By nickzl in forum G-Code Programing
    Last Post: 01-07-2012, 11:37 AM
  2. Autocad to gcode
    By JamesMI in forum Autodesk
    Last Post: 12-02-2011, 09:54 AM
  3. 3phase servo retrofit
    By whiteriver in forum Servo Motors / Drives
    Last Post: 02-07-2005, 04:27 AM
  4. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
