603,311 active members*
2,127 visitors online*
Results 1 to 1 of 1
    Jun 2023
    Gerber Sabre 408 poulies
    Hi all,
    I'm looking to replace all 3 (X, Y, Z) motors on a Geber Sabre 408 machine.
    The standard motors have 11mm diameter 35mm long shafts and to make things easier for myself, I would like to use new pulleys on the shafts.
    Does anyone know the specifics of the pulleys used?
    Thanks much to whoever has information.
    Other topic similar to this subject:
    https://en.industryarena.com/forum/n...e--270484.html
    Re: Gerber Sabre 408 poulies
    What I am planning on doing (based on a YouTube video, sort of), is use closed loop steppers, that have an 8mm shaft, then use add a 12mm rigid coupler attached with set screws.
    The video I saw had the OEM pulley drilled out to fit the coupler, I will try to lathe cut the coupler to the OEM 11mm size.
    Of course if the shaft is 35mm long, the bits I bought might not work but they are in the mail so too early to tell.
