587,999 active members*
2,186 visitors online*
    Sep 2007
    359
    Getting my feet wet
    So i am a long time Windoze user and Mach3 user.
    I want to make life easy for myself and have been doing lots of reading.
    I have had my mill working (Testing) and am very impressed
    But i don't want to get into bad habits, but also take a few short cuts
    My question relates to the custom.hal file
    As I will need a total of three Parports
    Can i just put all the port addresses in the custom file and leave the files created by stepconfig untouched.
    Any info on setup and use of a PoKeys as this has analogue inputs to use at speed & feed over ride.
    I have RTFM but didn't see any mention.
    Nov 2005
    496
    What version of stepconf are you using? the latest stepconf allows for loading three parports. The fist parport would be used for stepping axis the other two would need to be connected to signals in the custom HAL file.
    so to re-cap you can :
    load three parports with step conf
    The first one stepconf helps you set up signals for.
    the other two must be connected in a custom HAL file.
    The custom HAL file will not be over written.
    The INI and regular HAL file WILL be over written.
    You may get more answers about Pokeys in the EMC mailist
    Chris M
    Sep 2007
    359
    Hi Chris,
    Yeah thanks, I'm now getting the hang of it (Slowly). I have the stepconf that allows three parports.
    Got another issue will start another thread.
  1. Box Wrench for Leveling Feet
    By Donkey Hotey in forum Haas Mills
    Last Post: 08-07-2023, 08:05 AM
  2. Looking to get feet wet
    By xlatin in forum Benchtop Machines
    Last Post: 02-15-2010, 07:17 AM
  3. Jumping in with both feet
    By Marc Davis in forum Community Club House
    Last Post: 05-06-2009, 05:11 PM
  4. shoptask adjustable feet
    By leeharrysouth in forum Shopmaster/Shoptask
    Last Post: 02-22-2009, 03:54 PM
  5. Just getting my feet wet
    By Dabeechman in forum DIY CNC Router Table Machines
    Last Post: 10-05-2008, 12:55 PM
