Unfortunately those numbers do not tell much, you don't really need to know if you are using the same motors AND drives.
If you are changing the drives, then you may have to find out the specs by doing some tests.
Many of the motors on the older Cincinnati's were pretty big, as Getty's usually were.
If the resolvers went back to the control, you may have to switch them to encoders to be compatible with most systems.
You are lucky the drives are single phase, many were 3 phase.
Al.
Albert E.
