Originally Posted by
1newkid
If you want to modify a piece of existing geometry in Gibbs, the easiest way is to open Geometry Expert on the geometry creation pallet. Double click the geomety that you wish to modify. This will populate the table. Then by clicking on the element of interest ( radii, chamfer, diameter, etc), it will be highlighted in the table. Then simply make the change, and hit enter and viola, your done.
The only problem with this (I haven't used it recently) is that if that geometry chain you double click on is not a closed chain, the endpoints will disconnect.
Very annoying.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
