Re: GME's New 80/20 CNC Build - My Design
Long story short, it appears 80/20 does the processing.
What I am saying Gary is there can be different standards, one for Retail and another for CNCRP otherwise there would be hundreds of customers upset like you were when you received Your order. How else would you account for the customer satisfaction they have?
Mitsumi extrusion profiles can be had in many different configurations. BTW The ones I ordered when I was going to build my large scale laser were cut right to spec. They are used in many different applications without issues. The ones that are milled are an option for folks like you using the linear rail to insure the rail is mounted flat and true.
Speaking of milling is 80\20 also doing that for the CNCRP pieces they cut, the round holes for the fastners?
In any event we need to let this drop and let you get back to making your machine!
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
