In Mach4 (Lathe) while running a program (or MDI) going fromcommand G0 to G1 the program stops on G1 line without executing the commandbut, program clock is still running. Going from G1 to G0, G0 to G0 and G1 to G1all work. Everything works when the motion device is “Simulation”. The sameprogram (or MDI) in Mach3 (Lathe) works fine. Installing Mach4 on different computers didnot help. Went through Mach4 configuration screen trying numerous combinations ofswitches with no results. Mach3 (Lathe and Mill) worked for years with systemdescribed below never had any real problems. Switched back to Mach3 until thisproblem is resolved.
System:
I7 laptop with UC100 motion controller (w/Mach4update) and Gecko G540 Controller.
