Is there any good book or manual that show the detail steps of how to put togather a controller using mach3
campbell designs controller card for parallel port
geckodrive
power supply
and step motors
if there is any link will help.
Thanks.
geckodrive
power supply
and step motors
Thanks.
I have a friend who is writing a CNC book. Says it will take someone who just fell off the truck, show 'em step by step how to do every single thing. I know I want the first copy.
Like this?
http://www.homecnc.info/servomotor.htm
Do a search on CNCZONE for "controler schematic" -
"If you have great talents, industry will improve them; if you have but moderate abilities, industry will supply their deficiency." *Sir Joshua Reynolds (1723 - 1792)
this box look very good, I will check with them,
on the other hand I am also working on a project to retrofit a old cnc router, it has the step motors, 4 in total.
give me some suggestion why you choose servo motor for your application, I have this option too but the things I need to cut are small and they are step by step cutting, I need them cut good and reasonable fast. And I am thinking to use the gecko GRex 100 with 5 G202 to drive the step motor.
Where do you buy the power supply?
btw I cannot see your pdf in your link
Thanks.
Can you get more info about what content is on the book, I like something that has link what is good or tested and how to hook them up together?
thanks.
Home Shop Machinist magazine also ran a good series on this about 6 months ago. Cardinal Engineering was the author.
Karl
