603,323 active members*
4,065 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Got my hands on a Dahlgren CNC router for $100
Results 1 to 19 of 19
    Sep 2006
    32
    Smile Got my hands on a Dahlgren CNC router for $100
    I got my hands on a Dahlgren CNC router for $100. I seem to be very solid and have ball screws for both axes. I am planning to rebuild the third axes so it has full cnc control instead of just on or off (up/down). The motors are Rapidsyn American Precision (Model 23D-6306C, 3.4VDC). As you can see, it runs off Radio Shack TSR-80 and it has a huge controller! The table is 12"x16". It is obsolete and outdate.
    My question is can I still use these old motors?
    What kind of controller can I use?
    Thanks.
    Attached Thumbnails Attached Thumbnails DSC02990.JPG   DSC02997.JPG   DSC03003.JPG   DSC03007.JPG
    Feb 2004
    1086
    Sure, those look to be stepper motors. Read more on this forum -- some Gecko drives (or whatever drives are in the machine may still work) should fix you up. Then, use a computer with Mach 3 to do control. Nice find!
    Ahren
    www.cncrouterparts.com
    Feb 2006
    1187
    I,m diggin the TRS80 that is amzing that one of those is still functioning. Great find.
    Jul 2004
    601
    You could probably sell that old computer to a collector and pay for the hole retrofit.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Apr 2006
    39
    that looks familiar!!
    Hey check out this thread. You're in good company. Glad to see someone else has resurrected a Dahlgren from the past
    http://www.cnczone.com/forums/showthread.php?t=48718
    Jan 2006
    153
    Back in the 80's Mike Dell was my neighbor in south Austin. I had a computer just like that and didn't know what to do with it, so I took it to him (at the time he had his little enterprise in his garage with a few employees), he saw the machine and offered me $40 for it. I jumped on that deal because it was given to me.
    As for your new (old) cnc machine.. That looks like a very cool machine.
    Sep 2006
    32
    I am finally getting around to start my CNC conversion. The old TSR-80 computer does not work. There are so many options for the step motor drives. I want a good quality accurate and smooth drive.
    I really like the Gecko G540 because it it all one self contained unit but seems pricy at $300. The preassembled drives from PROBOTIX is a better option at $35 for each axis. I am not really too sure about the $65 3-Axis drive from HobbyCNC.
    www.hobbycnc.com
    http://www.probotix.com/stepper_motor_drivers/
    http://www.geckodrive.com/product.aspx?c=3&i=14469
    What does the Gecko or PROBOTIX have that the Hobbycnc version does not?
    Is Gecko G540 a really good drive?
    What are other good quality drive (less then $300) for controlling the 3-Axis?
    Attached Thumbnails Attached Thumbnails g540_md.gif   hobbycnc-ez-1.jpg   ProboStep_large.jpg
    Sep 2006
    245
    Quote Originally Posted by samim View Post
    The Gecko is bipolar, giving you about 40% more torque than HobbyCNC from the same motors. It also has speed morphing that allows it to have high precision micro-stepping at low speed that morphs to full stepping at high speed. The Geckos are also fully assembled vs a kit. Supposedly, the Geckos are very fault tollerant. The HobbyCNC drivers can blow themselves up if you remove the motor (or your wiring breaks) while power is applied.
    I have the HobbyCNC and it is a great setup. I think the Gecko is a step up at a slightly higher price. I would have bought the Gecko if it was available at the time.
    Steve
    Sep 2006
    32
    If the Gecko is bipolar, then the drive have to be bipolar too. Correct?
    Is the G540 going to provide more "accurate" positioning?
    The G540 contains four of our G250 drives. Looks like a single G250 has about four times more components on the board then the single 3-axis HobbyCNC board.
    Thanks.
    Mar 2007
    122
    Geckos
    Hi Samim,
    If you'll look at some of the threads about Geckos, you'll be amazed at their policies.
    First time - S**t happens - Fix or replace for free
    Thereafter - Free evaluation of driver.
    Extremely good customer support.
    Always polite and very helpful.
    Have a crazy idea that the customer is important.
    Al
    Sep 2006
    245
    Thanks.
    Unipolar drivers can only drive 6 or 8 wire motors. Bipolar drivers can drive 4, 6, or 8 wire motors.
    Both designs will give you similar positioning accuracy. You probably end up with about 0.0001" positioning accuracy in a system with possibly 0.001" or more backlash. You don't really need that much positioning accuracy.
    The HobbyCNC driver uses a pre-configured driver chip and adds a few discrete resistors and voltage regulators. Each G250 uses an FPGA with discrete MOSFETs for the driver. It is really tiny. The G540 packages 4 G250s into a space that is about the same size as the HobbyCNC board.
    Steve
    Sep 2006
    32
    Sound like G540 is way to go.
    I will take apart the DB9 connector on my motor to see what type they are.
    Can the Gecko G540 drive Unipolar or Bipolar motors or just Bipolar only?
    This machine is really old and Rapidsyn is out of business. Do you think the G540 will be able to drive my motors?
    This machne has manual adjustment for the Z-Axis. I am planning to ad belt drive with a stepper motor so I will have full CNC axis. Any suggestions on stepper motors?
    Thanks.
    Sep 2006
    245
    Any bipolar driver can drive a 6 wire unipolar motor. Bipolar has 4 wires that connect to the 4 outside taps of the unipolar motor. The 2 center taps should be left floating (and protected from shorting to anything).
    Both the G540 and HobbyCNC boards will drive your existing motors that show 2.9A on the label. G540 supports up to 3.5A motors. HobbyCNC supports up to 3.0A.
    Steve
    Sep 2006
    32
    It looks like my stepper motor uses 6 wires.
    Attached Thumbnails Attached Thumbnails DSC04143.JPG   DSC04144.JPG   DSC04145.JPG
    Sep 2006
    32
    How do check the wires on the motors so I can hook them up to the drives?
    Sep 2007
    740
    Samim,
    read this first.
    http://www.geckodrive.com/upload/Step_motor_basics.pdf
    This will show what 6 wire motor connections look like.
    With a VOM you can find the 3 wires that go to each set of coils in the motors. Once you have that, you may be able to determine which wire is the the center tap by finding small differences in the ohm reading between pairs.
  17. #17
    May 2008
    1185
    If your TRS-80 is the 12 model it may be worth around $300 on ebay. That could buy a few drivers.
  18. #18
    Sep 2006
    32
    Since the motors are 3.4 VDC / 2.9A, can I use simple 12V Computer Powersupply?
  19. #19
    Jul 2009
    Our company still uses those old machines. The originals
    ran off of the old trash-80's. But the newer version ran off ofany PC with windows 98 or older. You said you still have
    the original control unit? Go to engravingsystemsllc.com
    and download free superpro software. The control units
    can be adjusted using this software for air-driven or z-axis
    tables. If your switching over alltogether, I would be
    willing to take the old motors off your hands.
  1. RFQ: Looking for someone who can make watch hands
    By amanson in forum Employment Opportunity
    Last Post: 08-01-2008, 01:26 AM
  2. Router Using 3/4" MDF (first router build)
    By eguy208 in forum CNC Wood Router Project Log
    Last Post: 04-11-2008, 04:33 PM
  3. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
