603,374 active members*
2,976 visitors online*
Results 1 to 16 of 16
    .gpp file? Milling cnc controller
    Which milling cnc controller used for Mynx series Nm 410 model no.?
    Which .gpp file used for this machine?
    Why in simulation mode shows round toolpath but practical on machine it becomes polyline toolpath?
    Why it happen?
    I already uncheck option (apporx. Arc by line )
    Suggest the post processor or milling cnc controller!
    In master cam there are many .gpp apps like ( cimco , master cam code expert)
    Where is it in solid cam?
    How can i set .nc prog. in x y z & r value?
    Please suggest!
    Thanks in advance.
    How can i edit toolpath manuallly?
    If i click toolpath edit it gives message:
    (Tpe changes will be ignored because of procedure change) what its mean?
    Oct 2013
    153
    Re: .gpp file? Milling cnc controller
    Do you have a post processor for your machine ? Does your machine use G code and M coeds ?
    No but in master cam default post processor are applicable on machine. But same as default post processor for solid cam change round toolpath into polyline toolpath. Why it so?
    Yes machine uses g & m codes
    Oct 2013
    153
    Solidcam cam have an array of post processors . Choose one from there and modify it to suit your machine. Normally tapping cycles and tool change etc would be different. Example the gmilling_Hass_SS_3x would work fine .
    gmilling-hass ss 3x is fine .
    But it sets prog. in x y z i j cordinates.
    But machine reads x y z r value.
    How can i set into x y z r value?
    Please suggest
    Oct 2013
    153
    It's in the Gpp file . Go through the user options and change the iArcmode to 4
    Thanks for answer
    Please explain it where is user option?
    .gpp file is open in notepad.( .tap file) or any another program to run this?
    Where are these user option?
    Please elaborate i am new to solid cam.
    Oct 2013
    153
    Open the Gpp file with a notepad and search for @usr_ip_useroptions and read every option carefully . Those option are for the user to change . The one you looking for is iArcmode which is under the header "motion". Make a copy of it before you start to change something !
    Oct 2013
    153
    Watch the video to under stand Gpp file
    Post Processor Training Course - YouTube
    Jul 2009
    152
    That's a good video, I have watch it many time to bad he never put up part two of it.
    Rick
    Where is ultra edit software for opening .prp or .gpp file shown in video?
    I have notepad only for open these files. Is it ok?
    Oct 2013
    153
    You can edit the gpp files with notepad no problem with it . Ultra edit is a bit more easier
    Where i can install ultra edit?
    Oct 2013
    153
  1. mpc6515 controller/ usb file problem
    By Samijayne19 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-23-2020, 12:24 AM
  2. .dxf file for cnc milling
    By larry53 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-09-2015, 10:38 PM
  3. Step file 3D Milling
    By Koblenzer in forum BobCad-Cam
    Last Post: 08-24-2011, 06:36 PM
  4. controller file for Amada Octo
    By swift in forum Fanuc
    Last Post: 09-05-2010, 03:44 PM
  5. need fabuc controller file
    By fsa in forum Fanuc
    Last Post: 01-17-2010, 03:52 PM
