I have been playing around with the graphic feature but can't seem to get it to work. Would like to use it to check the toolpath. I can't seem to see anything at the plotting screen. Help
Damon1313
Damon1313
You need to first put in your dimensions for x- and z- axis in the Graphic Parameter sheet. So 2 inches wil be 2000. Lock your machine's axis's ( Machine Lock) if necesary and press start wil on Graphic sheet.
If this doesn't work check Parameter 6510 (DRAWING COORD.) I have mine on 4.
I only use graphic on my Lathe.
