603,946 active members*
2,382 visitors online*
    Jun 2024
    Gravograph LS800 help
    Gravograph LS800 control panel not powering up. I can hear the fans come on, but the control panel will not come on. The contol panel is loose. My question is, is there a pressure switch in the control panel that has to make contact to power up? Has anyone had this same problem with the control panel not powering up?
    Jun 2024
    Re: Gravograph LS800 help
    It sounds like the loose control panel might be the issue. First, power off and unplug the machine for safety. Check the connections between the control panel and the main unit; a loose or disconnected cable could be the cause. Tighten any loose screws or connections securing the control panel. There isn't typically a pressure switch that needs to make contact for it to power up, but ensuring all connections are secure might resolve the issue.
  1. Gravograph LS900
    By felipe909 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-23-2024, 06:26 AM
  2. Replies: 0
    Last Post: 05-30-2021, 04:22 PM
  3. VXm gravograph
    By Krutron in forum Engraving Machines
    Last Post: 01-06-2016, 09:15 PM
  4. Gravograph vx2
    By david88eve in forum Engraving Machines
    Last Post: 10-10-2014, 06:01 AM
  5. Old Gravograph vx
    By killerspost in forum Engraving Machines
    Last Post: 09-10-2013, 10:00 PM
