588,227 active members*
4,765 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Great Stuff expanding insulation for lost foam molds?
Results 1 to 9 of 9
    Mar 2004
    761
    Has anyone tried "Great Stuff" expanding insulation for lost foam molds?
    Wayne Hill
    Nov 2004
    138
    Quote Originally Posted by WayneHill
    I never thought of that, It might be too dense but if it works please post your experiance with it.
    Jun 2004
    22
    Tried it after ignoring everyone telling me
    all the hazards of vaporizing urethane foam
    It off gasses really nasty stuff.
    Any ways all it did was blow most of the molten
    metal back at me. I never was able to vent enough
    to get a good casting.
    There is a new latex canned foam havent tried
    that yet.
    If your going to experiment with molds make
    sure you use a lot of release agent or you just
    glue your mold together.
    Brad Stilley
    Jun 2005
    65
    there is another type of foam you can get at places like TAP Plastics that is a 2 part mixture. i have no idea if this would perform better as a lost foam material, but it will cure without waiting as it doesn't depend on humidity and has a lot bigger bubbles.
    Jul 2004
    100
    I have tried it and will not again. Here are the problems;
    Toxic and stinky.
    Too dense.
    Too much gas generated when burned.
    Foam at the center of the part does not cure while in the mold. Foam parts removed from the mold swell-up. Even tiny parts have this problem even when left in the mold for days and days.
    Go with expandable beads. - Ray
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Nov 2005
    3
    urethane vs styrene
    Hello,
    I suspect one of the reasons that urethane or other 2-part foams don't work well for lost-foam casting is that they're not really made to melt like styrene is...
    I've wondered about floral foam, haven't played with it, but I wonder if it's a styrene variant.
    Thanks,
    Kevn
    May 2006
    9
    Quote Originally Posted by klambson
    Thanks,
    Kevn
    Through some Googling I have found that Floral Foam is a phenolic resin foam.
    Here's a link to an MSDS: http://www.fdionline.net/Files/MSDS/...oam6-05-05.pdf
    The first box at the top of page 3 is giving me evil ideas. :bat:
    Jan 2005
    1880
    Toxic and stinky.
    Too dense.
    Ray- were do you optain expandable beads?
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Jul 2004
    100
    https://duckdeco.dkgnet.com/appiesho...:CKIE:prod017+
    I have never used it, but would love to try someday when my work load decides to cease and desist! - Ray
  1. great stuff to work with
    By trubleshtr in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 02-07-2009, 04:41 AM
  2. Expanding foam beads
    By TinkerDJ in forum Moldmaking
    Last Post: 04-29-2005, 07:48 AM
