I'm trying to find out what kind of connectors these green ones are. Anyone know the manufacturer or where to get any? I only need the PCB mounted part.
There is no picture, but from what I would guess is that they have a PCB part and a plug in part that has screw wire termination?
If so they come in different pad spacing and terminal count, usually from 2 to 10.
Weidmuller, Pheonix Contact, Entrelec and several others make them, I believe Amp also.
You should find them in DigiKey Newark or most of the online electronic vendors.
Al.
Albert E.
yeah they are 2 parts. i've checked newark and digikey and allied and keystone but can't seem to find them. I can find similar connectors but I would like to have the same exact style.
Most of the manufacturers use different colours, but Weidmuller is mainly Orange, Phoenix Contact mainly Green and Entrelec Grey.
If you can find a Phoenix supplier you can most likely match them up.
Al.
Albert E.
i think they may be discontinued. i just checked phoenix's website and they are very similar but not quite the same. i may have to just use something else
