603,981 active members*
2,179 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G-REX > GREX100 Tester problems
Results 1 to 8 of 8
    Jun 2006
    41
    Ok, this is what I get on my screen. Ive tried maximizing minimizing, reinstalling video drivers, played with setting but still cant get the screen to display the reset and open button. Strange, it works on other PCs just fine, just not mine...Any ideas
    Nov 2004
    61
    Nope I have the same problem
    Jun 2006
    41
    I caved in and just reformatted the pc...It works now except im running into other issues not related to the Grex...
    Nov 2004
    61
    thats wierd as i have done that and it still comes up
    the same
    if you right click on the desktop what is your screen resolution in settings
    now that it is working
    just courious as
    I cant seem to get the buttons to show at all
    you have any sugestions
    and did the GrexTester.exe
    program work ok for you
    Jun 2006
    41
    My screen resolution is 1920x1200. I really have no real clue what the problem was but I dont think the resolution was the problem as I tried every possible resolution. So you cant see any buttons at all? It seems odd that yours doesn't work right after reformatting.
    Try redownloading the installation files from gecko and try it again. Try uninstalling your graphics card driver and trying the testor.
    Yes I got to the testor program to work and communicate with the pc. I had a small issue with the test.txt fill not working at first but it all works now.
    Ill let you know what ever I find out. Sorry I cant be of more help but I am not too great with computers.
    Nov 2004
    61
    I just tried to install norton works to run some tests to check for problems I ran some tests and went to uninstall it
    and it kept freezing during the uninstall
    I cant get the dang thing to boot now
    so I think I will try a fresh start I just orderd a new hard drive
    and I am ging to be carfull during the install
    and go from there
    looks like there is a file in the dounloads
    that help you get it set up
    I was just reading it called optimize XP for mach3 I believe
    well thanks for trying to help
    Mar 2003
    35494
    Most people do not need to do the optimization steps. I wouldn't install any anti-virus software on the machine control PC, either. I've heard of Norton causing all sorts of problems.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2006
    41
    Well I got good news this time. First off, I managed to get the Grex connected again so I could load firware again. It turns out that the problem was in my Internet Protocol (TCP/IP) Properties. Try putting the following IP address and Netmask that you see (NetMask should come up automatically) see in the pic. I got this information from the Firmware documentation. and this solved it for me. If things work out you will see that the LAN cable will have connection at some point while the GREX is booting.
    Please ask for any clarifacations, I am happy to help
  1. Replies: 3
    Last Post: 04-27-2007, 05:15 AM
  2. IIJ-Ⅱ Fully Automatic Oil Tester
    By fire4427zlm in forum News Announcements
    Last Post: 02-10-2007, 02:05 AM
  3. 'z' problems
    By bo whipkey in forum Mach Software (ArtSoft software)
    Last Post: 10-11-2006, 02:06 AM
  4. printer port tester
    By smarbaga in forum CNC Machine Related Electronics
    Last Post: 12-10-2005, 06:57 PM
  5. Building a Load Tester
    By lerman in forum Servo Motors / Drives
    Last Post: 11-06-2005, 04:10 PM
