603,967 active members*
1,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Grid shift or X datum move.
    Jun 2006
    35
    I have always always from setting up days to training had it so my X zero is the center of my ID pot.
    IE you never put an X offset in a drill.
    Now this new company i have started for, have a few habits one of them being i believe its wrong Q setting the side of drills as the X zero is out.
    This is a straight 2 axis lathe.
    Puma 250
    To get the zero back i can input the value in the External offset, or i used to use parameters to correct this but i cannot remember the parameters.
    Also once this is done i will need to reset the Qsetter for them, any ideas on the parameters for this as i cant find the manual.
    Its a meldas 500l series.
    I know this is an old post but ....
    ACCESSING THE MACHINE PARAMETERS
    1. GO TO THE ALARM/ DIAGN SCREEN
    2. PRESS THE PLC-I/F MENU
    3. KEY IN 1001 FOR THE DEVICE, CURSOR RIGHT 2 TIMES AND KEY IN M UNDER MODE
    4. PRESS THE INPUT KEY, AND THE (1001) ( ) ( M), WILL DISAPPEAR
    5. GO TO THE TOOL/ PARAM SCREEN
    These parameters are from a M625 manual the numbers may be different but the parameter name should be the same
    AXIS PARAMETERS
    (Grid Shift)
    2027 G28sft
    (Tool Sensor)
    2015 t1m1-
    2016 t1m1+
    gl
  1. Grid Shift
    By scuba in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2013, 02:10 PM
  2. Changing Datum
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 10-10-2008, 11:40 PM
  3. Move subspindle datum
    By Kai_DK in forum EdgeCam
    Last Post: 05-23-2008, 05:43 AM
  4. Datum Help Needed
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 05-28-2007, 05:22 PM
  5. Datum Shift with TNC530
    By Bubbles in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-20-2006, 11:23 PM
