Originally Posted by
rwskinner
Crevice Reamer, Thanks a million for the Driver Suggestions. This is exactly what I ended up ordering for my Grizzly 10x22. Should be in next week.
Glad it was a help to you.
[quote]I have a question (to anyone) regarding the ballscrews and couplings.
The couplings in Derek's list end up being very high by the time you buy both halves and the rubber from McMaster Carr you end up at $36 per coupling. I wonder why he went this way, wouldn't some good zero backlash, spiral couplings be much cheaper and much better? Opinions welcome.[quote]
Helical couplings are ALWAYS better than Lovejoy type.
I notice Derek did not have any bearings listed for the free end although he mentioned adding some later. Looks like McMaster #5972K327 12x32x10mm metal shielded ought to be good enough for the free end, especially being $4.41 each.
ANY bearing--even a bushing will work on the free end. It just has to contain whipping and allow the screw to be able to move laterally when it expands or contracts.
This will be my first endeavor thru CNC Land other than a few small projects and I don't want to mess it up too bad...
Thanks for any suggestions or opinions.
Richard
Welcome to the club Richard. Good luck with your conversion.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
