603,940 active members*
2,758 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Grizzly G0704 CNC Conversion Help
Results 1 to 4 of 4
    Jul 2014
    8
    I'm looking to get a grizzly g0704 mill and convert it to CNC. Grizzly.com has this retrofit kit: https://www.grizzly.com/products/Min...r-G0704/T25436, which looks like all of the electronics needed. Then CNCFusion.com has this kit: CNC Fusion, which looks like just the ball screws. Will I need both kits or just the Grizzly kit?
    Jun 2013
    75
    Re: Grizzly G0704 CNC Conversion Help
    Seems like the grizzly kit is a full kit using the stock screws. The CNC Fusion kit just comes with the motor mounts and with ball screws which is the difference here. Also the grizzly kit uses belt drive for the axis and the cnc Fusion kit are direct drive. You could go with the Fusion kit and get whatever electronics you want or just get the grizzly and later on add ball screws
    Sent from my XT907 using Tapatalk
    Sep 2012
    323
    Man that seems like a lot of money for just the motors, pulleys, belts, mounts and controller!
    I guess if you are looking for a true bolt on and go option, this may be appealing. It all depends on how much work you want to put into the machine.
    Andrew
    Quote Originally Posted by Propagandalf View Post
    You have more options you can consider, there are more conversion kit options out there, check my main page under CNC Kits and Plans. g0704.com
    Also several tried and true options for the G0704 electronics.
    The grizzly/flashcut packages main plus is the flashcut electronics and control software, Dave Decaussin formerly of Fadal raves about it.
    You can get as good or better performance from the more affordable packages IMO.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  1. Joe's G0704 Conversion
    By joecnc2006 in forum Benchtop Machines
    Last Post: 12-21-2014, 12:24 AM
  2. New G0704 - CNC Conversion
    By feederic in forum Benchtop Machines
    Last Post: 11-21-2012, 05:42 AM
  3. upgrading from g0704 conversion
    By dsdmax in forum Charter Oak Automation Support Forum
    Last Post: 12-01-2011, 11:39 PM
  4. G0704 Conversion
    By rcazwillis in forum Benchtop Machines
    Last Post: 07-17-2011, 03:27 PM
  5. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
