No mention of how this works?
No hammer required?
Galvan Electrical - Ground Rod Accessories
Slide Hammer?
Al.
No hammer required?
Slide Hammer?
Al.
Albert E.
Kinda looks like it. I like the ones you put on the end of your hammer drill. Much less work!
I just use my roto hammer no adapter needed just slip it over the rod and pull the trigger. It pounds it in real fast
Yeah, looks like a slide hammer to me.
When I drive them I use a fence post driver (Deluxe Post Driver - Tractor Supply Online Store) until it hits the ground and then finish it off with a sledge hammer.
Matt
A bit more on it, look quite neat if it works, and only 23Lbs.
Galvan Electrical Announces Introduction of Manual Universal Ground Rod Driver
Appears to be slide principle.
Al.
Albert E.
