587,103 active members*
3,871 visitors online*
Thread: Ground wire
    Nov 2008
    37
    Ground wire
    I'm wanting to make a jumper wire with a alligator clamp to go from my ground clamp to my steel. I was wanting to know if anybody knew what size was needed. I have a 1000.
    Jan 2008
    2247
    I recommend using the same gauge size wire that is used for the work ground clamp for your Hypertherm Powermax 1000. The 1000 is rated for 60 amps....so the wire could possibly carry current up to 60 amps. A # 6 AWG wire can handle 60 amps....for this application it is best to get a highly flexible, multi strand welding wire...usually available at weld supply stores. Larger is ok as well!
    Jim Colt
  1. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  2. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  3. To Ground or not to Ground That is the question!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 09:10 PM
  4. New Servo with ground wire
    By Larken in forum Automation Technology Products
    Last Post: 05-03-2007, 12:33 PM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
