Hoping someone can clear up a few things that have me a little confused and in the process help me fix a huge problem Im having.
I have a DIY CNC, a Momus 2.1 to be exact that Ive built and Im having some real issues with the wiring. First a quick rundown of what Im working with here.
Motors Nema 24 400 oz/in 3.5A
Drivers are the Longs/Leadshine/Keling type that are common.
PSU is 36V 15A
BOB is a standard C10
All that works fine, I have smooth motion in all axis and have them tuned to a nice conservative speed of 100IPM. No problems.
The trouble starts when I tried connecting some limit and home switches. I have an Estop switch on pin 10 of the BOB and it functions just fine.
I connected a lead to pin 15 and another to the 5V terminal next to it on the BOB and all hell broke loose. Motors starting making a grinding noise and erratically moving axis, shaking and all kinds of nastiness. On the Diagnostics screen the proper led's are lighting however indicating the switch is making contact.
Soooooo If I disconnect the wires to pins 15 and 5v, everything returns to normal. Same happened with other inputs I tried, 13, 11, etc.
So Im thinking I have some serious EMI going on here and that I may have to re-route some of my cabling.
All my cables are shielded throughout the machine but I did not connect the drains to anything because I wasnt sure where they went.
This im sure is at least part of my problem.
So to make a short story long...........Where do the drain wires connect for the various wires?
Ex: the power wires FROM the PSU to the Drivers. Do I connect the drain wire to the GND terminal of the PSU?
How about the signal wires FROM the BOB to the Drivers. Where does that drain wire go?
How about the wires FROM the Motors to the Drivers. Should those drain wires be connected somewhere as well?
Finally the wires Im using to connect the limit switches themselves also are shielded with drain, where does that go?
I appreciate any help!!
Thanks!!
Jim
