587,321 active members*
3,284 visitors online*
Results 1 to 17 of 17
    May 2007
    15
    guitar bodies
    hi guys
    I'm looking for 3d models of electric guitar bodies, if anyone can help me post them on here please....
    Jan 2007
    634
    As I have offered in many posts before, send me any 2D blueprints and I can try to make 3D models out of them for community use here.
    I have ArtCam and other tools for modeling most folks on here don't have, but don't have the facilities to physically cut anything larger than a few inches.
    Mar 2008
    17
    Just Send the 2d drawing and I'll make them 3D. Dxf, Dwg, or even on paper.
    Jun 2003
    2103
    Quote Originally Posted by Stepper Monkey View Post
    Quote Originally Posted by Powershaper View Post
    Guys if you really want to do the 3d from 2d thing and post it here for the community here is a site that has tons of guitar dxf and dwg files.
    http://www.guitarbuild.com/modules/m...oads/index.php
    I would love to help in this, but I honestly can't afford the time. Trying to make a living is hard work! Especially when you are always behind the 8-ball!
    Let me know if there are specific guitars needed and I can at least do some searching to see if I can find them.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Mar 2008
    17
    Vicros:
    My model is almost done. If you like it I may share it with you.
    It was made in Powershape, and I can sent you an IGES file.
    May 2008
    3
    so i need to know that, if i am to have a 3d version, is that then able to be take to a cnc machine and cut out, or are there other steps.
    and also i am looking for a 3d version of a ibanez rg model. i have a 3d model of a jem but i dont want the handle cutout. if someone has one of these please please please send me a copy of it to [email protected].
    cheers
    Once you have the 3D solid model you are good to go as far a machining your Guitar on a router.
    Mar 2008
    17
    Once you have a 3d model...
    It's just a matter of programing and milling.
    And having an available cnc or router...
    http://3design-andre.blogspot.com/
    Solid Model, CNC Program, Machine part on CNC Router, Sand. That's it
    Powershaper,
    Great looking model by the way.
    May 2008
    3
    ok cool thanks for the help guys. i shall take it to a factory around the corner from mine which has a cnc and try it. will post photos and let u know how it goes if its successful :P lol
    cheers
    Jul 2004
    32
    you dont need 3d model for cutting on a cnc...the only surfaces you need in 3d are the contours and neck backs
    Mar 2008
    17
    dbassva:
    You are right but I personally prefer to have a 3d model at hand wen cutting a guitar like this one.
    Or an arch top like the Gibson ES 355
    The Jem Body is from Martim Guhl, i just edited it, removed the handle and smothed the edges. Thanks Mike
    Attached Thumbnails Attached Thumbnails soft jem.jpg   simulating 2.JPG   simulating 3.JPG   JEM.jpg
    Dec 2008
    dbassva:
    do you have the dxf files for that? or any files where i could edit in 3d with solidworks or autocad? thanks
    Nov 2010
    Hello i want to make a gibson flying v and a jackson rhoads can you guys give me some blueprints or the measurements of those guitars?
    Feb 2011
    anyone familiar with the laguna swift for making guitar bodies and necks thanx chris
  17. #17
    Oct 2007
    1026
    the body does not require a 3d file ,this one here is a dxf file cleaned and modified a bit
    to create the gcode,then into mach3 and cut it.This is the simple part,but for the neck you need a 3d file
    [nomedia="http://www.youtube.com/watch?v=s7uuFaQdzAU"]YouTube - guitar rev[/nomedia]
  1. Aluminum Guitar
    By big_mak in forum Musical Instrument Design and Construction
    Last Post: 04-09-2018, 07:15 PM
  2. RFQ for Guitar modeling
    By osoloco69 in forum Employment Opportunity
    Last Post: 05-29-2008, 04:45 PM
  3. 3d cad cam for guitar building
    By belgrado in forum Uncategorised CAM Discussion
    Last Post: 12-05-2006, 10:34 PM
  4. archtop guitar
    By Pookie in forum Musical Instrument Design and Construction
    Last Post: 12-21-2003, 03:17 AM
