603,794 active members*
6,081 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > guitar neck modelling....
Results 1 to 10 of 10
    Apr 2003
    470
    I'm having particular trouble with modelling the contours of the rear of a guitar model that I'm working on.
    you can see below the type of contouring that I'm working on.
    Any Rhino gurus care to share the techniques that you would use to make a model like this?
    Apr 2003
    1361
    What pops to mind right away would be constructing four curves to outline the length, then using the Csec command to create section curves. Then you could use control points to manipulate the individual sections if necessary. Finally, the Loft command would create surfaces. You may want to do it in a couple of sections, then join (or merge) them after.
    Let me know how it works out.
    Dan
    Jun 2003
    20
    Lightbulb
    You might want to check with John Suhr. He's a Rhino & Mastercam user,as well as a guitar designer/builder maestro: http://www.suhrguitars.com/
    :rainfro:
    PS- I don't do chips, wood or otherwise
    Shine on,
    RayDOsity
    Jul 2003
    151
    Hi Anoel,
    I did this using sweep 2 rails. The neck I did was symetrical tho and I mirrored one side after I got what I thought was ok. Like Dan B said, I did it in sections and joined them afterward. His method may not require very much tweaking, tho. Mine did. Making the contour curves satisfactorily took quite a while. And then I showed control points on the surfaces before I joined them to manipulate out the rough spots. Turned out ok. Hope this helps.
    -Doug
    Mar 2003
    65
    NECKS
    I've been working on necks too! Still kinda rough and haven't got the headstock connected to the shaft and heel.
    I used the two rail sweep on the heel too.
    As you see I haven't been able to cap off the front and back of the headstock and the bottom of the heel.
    Twombo
    Apr 2003
    470
    This has turned out to be much more difficult than I had thought it would be. Oddly I have no problem modelling most things but the guitar neck has been a real pain in the butt... Symetrical necks (i.e. 3 tuners per side have proven to be much easier to model. Though would be a real pain in the butt to cut.) I've got a set of curves made for a tele neck but have yet to get a good surface. I'm going to try Pro-Desktop and see what I come up with next.
    Nathan
    Mar 2003
    93
    I digitized a strat neck on my Larken cnc router with digitizer.
    www.larkencnc.com
    You could also use the arm digitizer sold on the rhino website.
    Dec 2003
    180
    Routerman, what did you do with the point cloud after digitizing to create tool paths?
    Mar 2003
    93
    The larken digitizer outputs a 3d DXF surface. I used Surfer 3D (comes with the digitizer) to make a tool path. The term Cloud point seems misleading, because the order of the points is important. A cloud of points could create a mess, if the order is wrong.
    Dec 2003
    180
    I haven't messed with this a lot, but one thing that surprized me with Vector CADCAM was that you could drag a box to select the point cloud, then hit change/reorganize and it would organize the sequence in back and forth rows.
  1. 3d Guitar Modeling using Autocad
    By slpd in forum Autodesk
    Last Post: 11-15-2014, 06:58 PM
  2. Guitar dxf files and fret calculator.
    By ynneb in forum Musical Instrument Design and Construction
    Last Post: 06-15-2010, 08:09 PM
  3. Would anyone like to carve my guitar with their duplicarver?
    By omardottcom in forum Musical Instrument Design and Construction
    Last Post: 10-08-2006, 08:35 PM
  4. My neck needs adjusting
    By turmite in forum Rhino 3D
    Last Post: 10-29-2004, 12:59 PM
  5. Acoustic Guitar Rosettes
    By jemmyell in forum Musical Instrument Design and Construction
    Last Post: 07-17-2003, 05:26 AM
