587,997 active members*
1,965 visitors online*
Results 1 to 6 of 6
    Apr 2012
    82
    Gweike air assist only on when actually lasering???
    Is this possible? It would be nice to have it so that the air assist is only active while lasering as opposed to having it running all the time....
    Phil
    Oct 2012
    I but a switch box on the side of my machine with an exhaust fan switch, and one for the air assist. Easy enough to turn on and off now,
    Apr 2006
    251
    The controller does have an output to control air. You'd probably need a relay to switch any current. Lasercut has provision for air on/off but whether it actually all works I don't know.
    Apr 2012
    82
    Ill have to take a look at that.. Thanks!
    Nov 2009
    314
    Quote Originally Posted by phylo View Post
    Phil
    Hi ,
    Air assist could be on either lasering or runing without laser . Take XYZ lasers for example . Normally there is an air switch in front of machine for air on ; there is a adjusting screw beside laser head for control the air output .Keep it on or off as need . Air control by software also can be realized by an valve installation and wire connection . One custmer with 6535 controller had done with this operation .
    Best regards,
    XYZ Machinery
    Attached Thumbnails Attached Thumbnails Air switch in front.jpg   1290 X4 Laser head with screw control out put .jpg
    Jun 2009
    37
    I have my laser on a half switched outlet. I can switch on the water, air and exhaust pump with one switch on the wall next to the laser.
    With the water pump, it is best to have it on 30 seconds before starting to run the laser.
  1. Anyone lasering some furniture?
    By pontiacg5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2012, 10:32 PM
  2. Lasering Brass Plates
    By brogers1948 in forum Material Machining Solutions
    Last Post: 12-17-2012, 09:05 PM
  3. Thermark- is it conductive after lasering
    By cnctoolman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-25-2012, 02:17 AM
  4. Lasering service
    By Murfman in forum News Announcements
    Last Post: 07-05-2006, 05:27 PM
  5. Lasering PCB's?
    By Xerxes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-12-2005, 02:13 PM
