587,227 active members*
2,996 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > GWizard no longer displays plunge rate?
Results 1 to 6 of 6
    Oct 2013
    185
    I'm not sure if I'm missing something, but after updating GWizard, it no longer displays the plunge rate (see pic). Anybody else having the same issue?
Name:	Screen Shot 2016-02-21 at 12.14.57 PM.jpg
    Jun 2008
    1082
    Re: GWizard no longer displays plunge rate?
    Could that "48.6" waaay on the other side of the window be the plunge rate?
    Mar 2003
    35538
    Yeah, it looks like the interface doesn't stretch very elegantly.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2009
    610
    Yeah it's still there way to the right. At first the metric units threw me off. I was looking for it and saw the 48.6 across the screen, but quickly dismissed it because I could never plunge that fast in ANY material in IPM :-).
    Oct 2013
    185
    Thank you guys. I did not see it for the heck of it. I was quite in a rush (customer needed 3 steel forming tools within about a day). Just came up with my own number and it was fine
    Aug 2009
    610
    Glad to hear you got everything under control. If I can't get a calculated value I typically plunge center cutting carbide end mills at <15% of whatever the last successful horizontal feed at full diameter DOC was. Anything more than that is usually a recipe for a fried end mill unless my horizontal feeds are way off.
  1. feed rate and plunge rate help required please
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 12-07-2015, 09:30 AM
  2. What feed/plunge rate for this?
    By alank2 in forum WoodWorking Topics
    Last Post: 05-13-2012, 05:31 AM
  3. Can you plunge an endmill longer than the cutting edges?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2012, 01:53 PM
  4. Control Plunge rate & Retract rate
    By GEORGETOUBALIS in forum G-Code Programing
    Last Post: 04-13-2009, 12:12 PM
