Thanks in advance for any suggestions here.
I have a 94 VF0 that has possibly developed a low voltage problem. First thing yesterday I got a 163 Alert (Z axis over current or drive fault). Hit reset, same alert, reset, same alert. After 4-5 times, the 163 alert went away but then got a 161 Alert (X axis over current or drive fault). Checked connections, tested voltage, swapped boards between X,Y, and Z, and now have both a 161 and 162 Alert (X and Y over current or drive fault). I read on some early posts that a problem could exist with a low voltage transformer. I see 4 low voltage transformers on the Servo Dist. PCB. Are these the low voltage transfer that were referred to in earlier posts?
Again, thanks in advance for any suggestions.
