603,795 active members*
2,896 visitors online*
    Jul 2006
    18
    haas hl2 lathe
    Just wondering what it would take to change my "G32" threading routine to a "G76" my Haas is a little to old to understand the "G32"
    I did try just changing the 32 to a 76 and the lathe still wasn't happy.
    Mar 2006
    158
    Presuming that the Haas is similar to the Fanuc version, you need two lines of G76 code for it to work.
    Check a Fanuc manual for details, since you did not provide any thread or material details for the crowd.
    Odd that G32 did not work, but did you try using G92?
    Jul 2006
    18
    This a just an 8tpi cut, and im not cutting anything yet, im just using the verify that's on the control. The error message I get with the "G32" is Invalid G code. I took a look in the Haas manual and "G32" isn't even listed, just "G76" for threading. When I changed the "G32" to a "G76" is says Invalid I,J,K values. Because their aren't any when using a "G32" I tried the "G92" and it when thru the program ok, looks like it did a turning routine, didn't cut any threads. This Haas will thread all day with a "G76". Thinking this 1996 HL is just a little to old for the newer G Codes.
  1. haas lathe advice
    By crazycnc in forum Haas Lathes
    Last Post: 10-31-2012, 02:43 AM
  2. Haas Lathe VQC
    By stridharn in forum Haas Lathes
    Last Post: 09-19-2012, 10:51 PM
  3. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  4. Engraving on Haas lathe
    By cnc1968 in forum Haas Lathes
    Last Post: 10-30-2011, 07:24 PM
  5. ?????HAAS CNC LATHE?????????
    By JROM in forum Haas Lathes
    Last Post: 06-04-2008, 06:51 PM
