603,912 active members*
3,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas hl2 tailstock not reading position
Results 1 to 5 of 5
    Mar 2013
    15
    I recently purchased a 1998 haas hl2 and after hooking up I can't get tailstock to home, I can get it to move, but positioning doesn't show any dimensions other than 0.0
    Mar 2013
    15
    I guess when I posted this I should have asked for help, is there somewhere I can start looking at to find the problem??
    Feb 2010
    1184
    When you try to home the tailstock, does it move at all? If yes, what direction.
    If no, are you able to move it manually using the jog wheel or how are you getting it to move?
    Mar 2013
    15
    Thanks Guys, It turned out it was a tailstock encoder.
    Feb 2009
    4
    How did you find the problem with the encoder? I'm am having the same problem with a HL2. It moves but thinks home is in the middle of the machine.
  1. Reading Current Position in C program?
    By LJsmith in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-03-2013, 08:37 AM
  2. Haas pre-reading macro
    By kenickie22 in forum Haas Mills
    Last Post: 06-14-2012, 08:13 PM
  3. Doosan Tailstock home position problem
    By secretsquirel in forum Daewoo/Doosan
    Last Post: 01-17-2010, 07:12 PM
  4. Tailstock position recovery
    By kkungfu in forum Mori Seiki lathes
    Last Post: 06-17-2009, 06:33 AM
  5. haas vf-4 mill not reading code
    By WhiteZee in forum Haas Mills
    Last Post: 06-09-2007, 08:53 PM
