588,199 active members*
4,739 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HAAS ST30 Can you reverse the X values
Results 1 to 4 of 4
    Dec 2007
    44
    We have a new HAAS ST30, we have a Gibbs POST that posts everything great but the X values are reversed (ie X1. = X-1.)
    Before I start looking through the machine settings, anyone know off hand if there is a setting to reverse the values?
    Thanks guys CHEERS!
    Dec 2007
    44
    Re: HAAS ST30 Can you reverse the X values
    never mind found one that works correctly
    Nov 2010
    73
    1) 45 setting will change the direction of movement of the X-axis,
    2) Advanced Editor allows you to change the sign - on the + sign for all X values in the program.
    3) Try to change the construction of the part geometry in a computer program, the value for X in the construction of the geometry should be positive.
    Feb 2007
    381
    Quote Originally Posted by houdini View Post
    Thanks guys CHEERS!
    Instead of changing machine parameters, why not talk to Gibbs about getting the post corrected so that it posts correctly? There may even be a setting in there that you are missing. I know in Partmaker each tool has a check box to allow you to specify "negative diameter". I would think there is something similar in Gibbs. That would make more sense than messing with parameters in the machine. Make the software follow what the machine is setup for, not the other way around.
    Just my $0.02.
    Mike
  1. HAAS ST30 Turret Alignment Procedure
    By jcool144 in forum Haas Lathes
    Last Post: 04-29-2017, 12:16 AM
  2. Need HAAS ST30 post, for our old 2006 software
    By houdini in forum GibbsCAM
    Last Post: 02-09-2017, 06:14 PM
  3. Need post for HAAS ST30 (or ST35)
    By lookynator in forum GibbsCAM
    Last Post: 01-12-2017, 03:06 PM
  4. How to change post (reverse sign, double values)
    By darryl lee in forum BobCad-Cam
    Last Post: 06-07-2011, 04:14 PM
