587,638 active members*
4,279 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS TM Model Mills - Coolant System
Results 1 to 5 of 5
    Sep 2006
    17
    Hey everyone, I looking to upgrade my standard 5 gallan coolant tank that comes with the TM mills to a lager tank. About 20 Gallons. I would like to be able to use my Pump that came with the system and the screen. Is there anyone who makes a larger tank that would work for this?
    Thanks in advance.
    Josh
    PTPmfg.com
    Jan 2005
    71
    Cool tank upgrade
    We had ours custom made by a sheet metal shop. It works great. we reused the pump that came with the original.
    Rules of my Road: Don't do what you will regret! Never regret anything you do!
    Sep 2006
    17
    Gandalf,
    Yeah that's what I was thinking. I've been looking around for one for a while now. I talked it over with the shop that does all of our fab work and I think we may make our own. I think I'll sketch up some plans and 3d a tank out in CAD and post some pictures. Maybe if I decide to make one i'll make a few and see if anyone else could use one.
    Josh
    ptpmfg.com
    Feb 2007
    246
    Getting one made custom is the way to go, the old pump should work fine as Gandalf said.
    I hate how small the coolant tanks are on the TM series, its such a pain in the ass. Its even worse with the TL series lathes, you need a pail full ready at all times because it leaks everywear and is super tiny.
    Jul 2006
    27
    You might try a water or waste water tank at your local boating store. They come in a variety of sizes and shapes.
    Rick
  1. Fanuc system 6M model B
    By Olsson in forum Fanuc
    Last Post: 01-29-2016, 09:31 AM
  2. haas mills
    By 1cnchogger in forum Haas Mills
    Last Post: 02-02-2007, 01:41 AM
  3. Haas TL-2 Coolant ?
    By 100 in forum Haas Mills
    Last Post: 04-14-2006, 11:11 PM
  4. coolant system
    By mtechserv in forum MetalWork Discussion
    Last Post: 03-27-2005, 07:09 PM
  5. Cheap coolant system
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2004, 08:03 PM
