588,655 active members*
5,846 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS VF-2 (104 ALARM) Y SERVO ERROR TOO LARGE
Results 1 to 4 of 4
    Jun 2008
    18
    Hello all,
    we have a VF-2 HAAS MILLING MACHINE and we get the alarm 104 about the "Y servo error too large" we need and also appreciated help from your.
    thanks in advanced
    Joanpim
    Aug 2011
    may be the servo motor encoder is defective or the amplifier.
    switch the amplifier of x axis to y axis connection if alarm occur the amplifier and servo might be the problem
    Sep 2011
    26
    Hello sir, did you find what was the problem with the "Y servo error too large"? I have it on the X axis. will apreciate it.
    Aug 2011
    Quote Originally Posted by beto81 View Post
    Hello Sir. I find the amplifier has defective fuse, then try to check the continuity of the board, try to open the amplifier of y axis to see the matching of ohmmeter reading
  1. 434 servo alarm: Z axis detect error
    By padobranac in forum Fanuc
    Last Post: 12-21-2021, 03:18 PM
  2. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  3. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  4. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  5. Replies: 4
    Last Post: 08-12-2008, 11:01 AM
