CAT40 20 Tool
CAT40 10 Tool
Replace your OEM cast tool disk!
Visit http://www.buycmi.com for more information or call 517-529-9454.
CAT40 20 Tool
CAT40 10 Tool
Clarklake Machine, Inc. - Precision Machining and Assembles
http://ClarklakeMachine.com - 517.529.9454
That is a thing of beauty.
Lessen the Severity of Carousel Crashes
By Charles Bates | For the American Machinist | Penton Media, Inc.
American Machinist Articles
Severe machine crashes seem to be inevitable, but now, when they happen, shops can replace only the damaged segments of a vertical machining centers tool disk instead of the whole carousel-type disk. What makes this possible is a retrofitted CMI Segmented Tool Disk from Clarklake Machine Inc.
Often, after crashes due to accidents, machine malfunctions, operator errors or taper locks caused by debris or heat, operators must replace a machines entire one-piece stock tool disk. The CMI tool disk, made for Haas VF-Series CAT-40 20- tool machining centers, incorporates individual segments that are attached to a base plate and are replaceable.
The tool disk is made of precision-machined 6061-T6 billet aluminum. If the segmented disk becomes damaged, only the effected segments are replaced. Preassembled, the 21-piece unit has 20 segmented tool pockets and one base plate. This is also a "green" technology that helps reduce the overall carbon footprint of high-tech CNC equipment.
CMI Segmented Tool Disks feature removable segments that allow shops to replace only damaged portions after a machine crash.
CMI News
