587,472 active members*
3,290 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS VF1 replaced battery now multiple alarms on startup
    May 2009
    4
    I had to replace the battery in a VF1.
    here's the kicker, you can't take out the old battery without loosing the parameter so i just wired the new battery in in paralell with it.
    After putting it back together and startup i get multiple alarms including.
    rotary axix error
    spindle temp overload
    servo motor overload
    and then it does an autoshutdown thing after 15 seconds.
    any hints before we have to call a tech.
    my thinking is that i jarred the battery and lost the parameters and the parameter for overload temp and conditions defaulted to 0.
    this should have been simple enough but appearently not.
    anyone see any flaws to my procedure?
    any help would be much appreciated!
    thanx.
    Oct 2011
    5
    just did the same thing and i have all the same errors. I really hope you reply to this! I know its been years. Thanks. What did you do?
    Dec 2008
    717
    Quote Originally Posted by durb69 View Post
    Well...given the two of you have a combined total of 9 posts in 8 years I have my doubts...My suggestion is it is time to call your HFO tech line. Thankfully I haven't had to replace that thing yet...
    Tim
  1. Replies: 40
    Last Post: 02-08-2008, 12:03 AM
  2. Haas startup error
    By Crash in forum Haas Mills
    Last Post: 12-04-2007, 05:15 PM
  3. HAAS VF1 Startup Problem
    By rkdygert in forum Haas Mills
    Last Post: 07-25-2007, 12:59 AM
  4. Haas mill multiple vise question (programming)
    By joesimmers in forum Haas Mills
    Last Post: 03-29-2007, 11:48 AM
  5. Haas VFE alarms
    By TGriz in forum Haas Mills
    Last Post: 10-02-2006, 07:01 PM
