587,656 active members*
9,068 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas vfo z axis height problem
Results 1 to 5 of 5
    s00073055 Guest
    New problem i notice a while back that my z level was getting lower when machining you would hardly notice it i couldn't find a reason for the change in height at the time then the machine crashed doing a tool change and now the head has dropped below the the tool change height got new encoder no difference checked lead screw bearing and locking nuts there ok checked coupling and drive keys in the coupling to the z axis motor all seems ok what am i missing any help would be great thank. (I don't know if this would have cause a problem or not but i had to replace the low voltage power supply which supply's the 5v,12v, and -12v to the PCBs)
    Jul 2014
    17
    Re: Haas vfo z axis height problem
    Check the Z axis prox switch.
    Feb 2010
    1184
    Quote Originally Posted by s00073055 View Post
    Does this machine have a nitrogen counter balance? If so, check your system pressure and adjust if needed.
    s00073055 Guest
    Quote Originally Posted by haastec View Post
    It is a weighted counter balance I found my problem today the collar with the two small grub screws to tighten the new encoder to the motor shaft was in the wrong place to grip the shaft properly when tighten Thanks
    Feb 2010
    1184
    Glad you got it figured out!!
  1. Torch Cut Height Problem
    By whutth in forum Waterjet General Topics
    Last Post: 02-07-2016, 04:20 AM
  2. Haas VF-5/50 X axis overload problem
    By CNC314 in forum Haas Mills
    Last Post: 05-28-2015, 04:52 PM
  3. haas 4th axis problem
    By mattfurches in forum Haas Mills
    Last Post: 05-08-2012, 06:08 PM
  4. 4 th axis rapid height Problem (V24)
    By woffler in forum BobCad-Cam
    Last Post: 04-20-2012, 06:01 PM
  5. Carousel height problem
    By TiaanK in forum Haas Mills
    Last Post: 05-11-2011, 11:22 AM
