603,385 active members*
3,947 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Hacking a series wound universal motor to build a constant speed motor ?
Results 1 to 4 of 4
    Mar 2014
    5
    Hi All,
    Is there a possibility of modifying a series wound universal motor (AC) as a shunt wound universal motor to make a constant speed motor ?
    Nov 2013
    88
    Re: Hacking a series wound universal motor to build a constant speed motor ?
    A universal motor series or shunt wound run about the same, that wouldnt make it constant speed.
    Both types are happy to run from DC to maybe as high as 400 hertz AC with very little change in rpms no load, but they both have very poor speed regulation.
    A speed control with tach feedback maybe could keep both types running at a stable speed, but theres much better motors out there for that type of control (permanent magnet or 3 phase).
    Dec 2003
    24260
    There are controllers out there with tach feedback such as SuperPID, see Lengthy thread here on it.
    Al.
    Albert E.
    Mar 2014
    5
    Thanks cgo. but shunt motors are said to have speed regulation!
    Al_The_Man, that's cool. It seems this address my requirement.
  1. Wound Rotor DC motor control
    By DSpeck in forum CNC Machine Related Electronics
    Last Post: 06-01-2013, 04:38 PM
  2. I need help hacking the Milwaukee 5625 router motor...
    By maspeir in forum DIY CNC Router Table Machines
    Last Post: 12-23-2010, 12:05 AM
  3. Replies: 1
    Last Post: 04-13-2010, 10:16 PM
  4. Triac DC motor speed control build schematics?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 11-27-2008, 11:35 AM
  5. dc series universal motor
    By jed102 in forum Servo Motors / Drives
    Last Post: 05-03-2007, 03:09 AM
