587,201 active members*
3,023 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Had something wierd happen yesterday
    Mar 2009
    1863
    A few days ago, the PDB on my 1100 wouldn't release the collet to change tools. I thought, no problem, I would just remove the collet, clean it and apply some fresh anti-sieze. I did that and all was fine.
    Then yesterday it happened again. I couldn't get the PDB to release the collet. I was really getting frustrated so I opened the door around the motor and when I cycled the PDB I saw the problem. All the bolts on the bottom of the PDB gas cole loose and when I stepped on the pedal, the air cylinder would lift almost 3/4 of an inch. I needed a 12 MM allen wrench to fix the problem and of course, this happened right at noon, on Saturday and all the industrial suppliers close at noon and I was 30 miles away from the nearest supplier and McMaster is a little over 50 miles away.
    Fortunately, my local Sears store had one 12 MM allen wrench in stock. Man, were they proud of it. They charges me $8.00 for it. But at least I was able to work today.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Oct 2011
    477
    Similar thing happened to me when I had to change out a leaking drawbar cylinder on my 1100 on Friday night three weeks ago after I had gotten in off the road. I did not have a 12mm wrench.
    Went Sears at 8:30pm and "no we don't have a 12mm Allen Key but we do have one 1/2" wrench, same thing" says the kid proudly. No, I said it is not the same, but at this point it was take it or leave it, work or sit. Took it home.
    I also paid +/- $8.00USD then spent another hour and a half setting it up and grinding it to 12mm. But now I have a very special Hybrid Allen Key that is 1/2" on one end and 12mm on the other.
    nitewatchman
  1. wierd problem on our tc-22 z axis please help!!!
    By bedfordia in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2013, 01:49 PM
  2. A wierd shaped block
    By cncadmin in forum EnRoute
    Last Post: 02-15-2012, 08:10 AM
  3. Fanuc PMC: wierd FIN signal?
    By Jung in forum Fanuc
    Last Post: 02-04-2008, 09:18 AM
  4. Wierd z axes problem
    By jonmessenger in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-01-2007, 10:49 PM
