Re: Hafco 12x36 CNC conversion
![Quote](images/misc/quote_icon.png)
Originally Posted by
proengines
I'll be ditching the compound now after reading how to chase threads using Mach, it seems fairly simple to do. I also came across the auto toolposts on salecnc.com from China for $690 which might be worth some more investigation, It looks the same as the ones that microkinetics use:
Maybe that plus a QCTP on the rear might be worth a look?
As for an enclosure, I want something that seals up the chuck area well but leaves the tail end of the lathe open. Maybe something that lifts up on gas struts or rolls back out of the way might be the go.
690 for that? Overpriced. A lot of that type have a problem where certain tools will interfere (hit) the motor.
