587,773 active members*
3,237 visitors online*
    Apr 2009
    10
    Handlewheel problems tnc426 heidenhain.
    Hello to everybody.
    I realized last week that while on machining if I set the machine in manual mode (under "stop " manual operation ") i can move the machine with the handle without needing to press the safety buttons.
    That means that if I drop the handle by mistake and it hits the wheel the machine is going to move in the activated axis and there is a risk of damage on the tool or the piece.
    But is it normal ???
    i dont know since how long its going that way.
    There should be some data inside the control parameters that has changed, you guys have an idea what it might be ?
    here is a link to what kind of handle i have
    http://www.usinages.com/ressources/image/210021 safety buttons with red arrows.
    it's the HR410 handle.
    Thank you
    Dec 2011
    99
    Re: Handlewheel problems tnc426 heidenhain.
    You need to change the PLC program. Contact the manufacturer of the machine!
  1. Zayer milling m/c with Heidenhain TNC426
    By balavishe in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2024, 04:52 AM
  2. Replies: 0
    Last Post: 07-24-2014, 05:36 PM
  3. Heidenhain TNC410 and TNC426 or alternative?
    By Stuki-5 in forum BobCad Post Processors
    Last Post: 05-06-2014, 10:11 AM
  4. Post processor Heidenhain TNC410 and TNC426
    By Stuki-5 in forum Tutorials
    Last Post: 03-05-2014, 11:00 PM
  5. visualmill Postprosessor for heidenhain tnc426/430
    By latexii in forum Visual Mill
    Last Post: 06-01-2012, 01:39 PM
