567,245 active members*
4,596 visitors online*
Results 1 to 1 of 1
    Oct 2022
    27
    Handwheel setup
    Hi
    I have a machine tool. The x, y, and z axes are moved by the handwheel, but I cannot move the b axis by the handwheel. I think the settings or the program have not been done for this. What should I do? What are the relevant parameters or g and f of the code that I should change in PMC?
    Dec 2009
    848
    Re: Handwheel setup
    The movement of the B axis by handwheel is done in PMC so you must have already created the conditions for this.
    You need to modify the PMC for this.
